Menu
Cart 0
HomeSeer Z-NET Remote Z-Wave Interface (US) - REFURBISHED
  • $ 99.95
  • SALE
Network-Connected Z-Wave Controller
Z-NET is a network-connected Z-Wave controller that's designed to send & receive Z-Wave commands from HomeSeer smart home software & hubs. Z-NET is the idea solution for improved performance in large homes or properties with outbuildings (like pool houses or barns)! Works with all HomeSeer systems.
  • Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
  • Supports Z-Wave Plus (and older) Products
  • Ethernet Connections Allow for Optimal Positioning in Home
  • Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
  • May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Includes Highly Optimized Antenna for Superior Range and Performance
  • Includes Easy to Use Web-Based Management Features
  • Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
  • Case Includes Keyhole slots for wall mounting (with your hardware)
  • Z-Wave Plus Certified
  • Protocol: Sigma Serial API
  • Built-in 500 Series Z-Wave Module
  • Includes ZDK 6.5x Z-Wave Library
  • Field-upgradable Firmware
  • Supports 908.42 MHz (US) Z-Wave frequency
  • UPC: 610585164310
  • Z-NET Unit
  • AC Power Supply
  • Micro USB Power Cable
  • Quckstart guide
  • 1-year manufacturer's warranty
  • Works with all HomeSeer HS3-based systems (including HomeTrollers)
  • Supports 908.42 MHz Z-Wave products
  • Ethernet-only; WiFi not available in this model
Condition
Refurbished stock includes customer returns that have been repaired or reconditioned to work 'as new'. Most refurbished items are in 'like new' condition but some may have slight cosmetic blemishes. All refurbished items come with the original manufacturer's warranty and are also covered by our 30-day return policy.
Customer Reviews
Based on 3 reviews Write a review
