HomeSeer HS-DS100+ Z-Wave Door / Window Sensor
Our Z-Wave door & window sensor updates your smart home hub when doors or windows are opened & closed. HS-DS100+ supports S2 security, is easy to set up, takes regular AAA batteries and comes with all the hardware you need to install quickly. Works with most popular smart hubs.
- Door / window sensor
- Uses conventional AAA batteries for easy battery changes
- Supports Z-Wave Plus Technology
- Supports S2 Security
- Small and Sleek design
Operation
Install the sensor on a door or window using the supplied hardware. Then pair it to your smart software or hub. A Z-Wave command will be broadcast every time the sensor is triggered. Battery status will also be updated daily.
- Power: (2) AAA batteries
- US Z-Wave Operation
- Z-Wave Plus Certified
- HS-DS100+ Sensor Body
- Magnet Piece
- Double stick tape
- Mounting screws
- (2) AAA alkaline batteries
- Manual
Important
- Requires US Z-Wave network
- If you're using version 4 of the Z-Wave plugin, you will need 4.0.1.0 or later.
- Compatible with HomeSeer, SmartThings & Wink hubs
Customer Reviews
Based on 24 reviews
Write a review
