Menu
Cart 0
HomeSeer HS-DS100+ Z-Wave Door / Window Sensor 3-Pack
  • $ 76.82
  • FALL SALE
Our Z-Wave door & window sensor updates your smart home hub when doors or windows are opened & closed. HS-DS100+ supports S2 security, is easy to set up, takes regular AAA batteries and comes with all the hardware you need to install quickly.Works with most popular smart hubs. This bundle includes 3 sensors.
  • Door / window sensor
  • Uses conventional AAA batteries for easy battery changes
  • Supports Z-Wave Plus Technology
  • Supports S2 Security
  • Small and Sleek design
Operation
Install the sensor on a door or window using the supplied hardware. Then pair it to your smart software or hub. A Z-Wave command will be broadcast every time the sensor is triggered. Battery status will also be updated daily.
  • Power: (2) AAA batteries
  • US Z-Wave Operation
  • Z-Wave Plus Certified
  • (3) HS-DS100+ Z-Wave door / window sensors
  • Magnet Pieces
  • Double stick tape
  • Mounting screws
  • (2) AAA alkaline batteries
  • Manual
Important
  • Requires US Z-Wave network
  • Compatible with HomeSeer, SmartThings & Wink hubs
Customer Reviews
Based on 6 reviews Write a review
