Menu
Cart 0
HomeSeer HS-FS100-L Z-Wave Indicator Light Sensor
  • $ 29.95
  • SALE
Z-Wave Smart Indicator Light Sensor
Want to turn your regular 'dumb' appliances into smart ones? HS-FS100-L is a Z-Wave light sensor that's designed to report back to your smart home hub when indicator lights turn on, turn off or change color. Use to monitor dehumidifiers, water softeners, washers, dryers and much more!
Suggested Uses
Think of all the things in your home that have indicator lights. Wouldn't it be great if you could keep track of them even when you're not at home? Now you can! Our new indicator light sensor monitors these lights and reports changes back to your smart home system or hub. Here are just a few things you can do with HS-FS100-L:
Receive notifications when a...
  • Dehumidifier needs to be emptied
  • Humidifier needs to be filled
  • Water softener needs more salt
  • Washing machine turns off
  • Dryer/Washer turns off
  • Computer or network equipment needs attention
  • Home entertainment gear turns on or off
  • Security panel lights come on
  • Heating or cooling equipment need attention
  • The freezer has stopped working, IE: unplugged
  • Air filter needs replacing
Video
  • Sensor Body
  • Mounting hardware
  • Indicator light cable with double-stick tape
  • Manual
  • US Z-Wave network
Important
  • Compatible with HomeSeer systems or with SmartThings hubs (with special device handler).
Customer Reviews
Based on 6 reviews Write a review
