Menu
Cart 0
HomeSeer HS-FS100 Flex Sensor
  • $ 25.95
  • SALE
Z-Wave Temperature Sensor & Buzzer
HS-FS100 is a multi-function Z-Wave device that may be used as a temperature sensor and buzzer. The unit may also be converted to work as a Z-Wave perimeter water sensor with the addition of a HomeSeer fluid sensing cable (not included).
  • Temperature Sensor
  • Z-Wave Controllable Buzzer
  • Works with optional indicator light cable or fluid sensing cable
  • Acts as a Z-Wave repeater when used with optional Micro USB power adapter
    Operation
    Install the unit where it will be used and pair it to your smart home software or hub. Z-Wave commands will be broadcast to update temperature data. Your can issued commands to the unit to sound the buzzer.
    • Power: Requires 3 AAA batteries or micro USB adapter (not supplied)
    • US Z-Wave Operation
    • Z-Wave Plus Certified
    • Guide
    • Sensor Body
    • Mounting hardware
    • Manual
    • US Z-Wave network
    Important
    • Compatible with HomeSeer systems or with SmartThings hubs (with special device handler).
    Customer Reviews
    Based on 2 reviews Write a review
