Menu
Cart 0
HomeSeer Z-NET G3 Remote Z-Wave Interface (BWP)
  • $ 149
Add to Cart
Network-Connected Z-Wave Controller
Z-NET is a network-connected 700 series Z-Wave Plus v2 controller that's designed to send & receive Z-Wave commandsĀ from HomeSeer (and Home Assistant) smart home software & hubs. Z-NET is the idea solution for improved performance in large homes or properties with outbuildings (like pool houses or barns)!
šŸ“¢ ALL NEW G3 Version | 700 series Z-Wave Plus v2 chip | User-configurable Z-Wave frequencies for US, EU, UK, AU, HK, MY, IL, IN, RU, CN, JP, KP
UPDATE
: Z-NET now supports Zigbee with optional Sonoff ZBDongle-E adapter! HomeSeer systems can manage multiple Z-Wave networks and a single Zigbee network.
  • Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
  • NEW: Built In 700 series Z-Wave Radio with User-selectable Z-Wave frequencies
  • Ethernet (and WiFi) Connections Allow for Optimal Positioning in Home
  • Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
  • May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Includes Highly Optimized Antenna for Superior Range and Performance
  • Includes Easy to Use Web-Based Management Features
  • Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
  • Case Includes Keyhole slots for wall mounting (with your hardware)
Includes International Z-Wave Module
Not in the US? No problem! Z-NET can now be configured to work around the world. Our Z-Wave module is now compatible with systems in the US, Canada, Europe, Australia, Hong Kong, Malaysia, India, Israel, Russia, China, Japan and Korea. Change the setting from your HomeSeer HS4-powered system.
Ā In the diagram below, a HomeTroller PRO hub is connected to two Z-NETs, one of which is controlling both Z-Wave and Zigbee products.
  • Z-Wave Plus Certified
  • Protocol: Sigma Serial API
  • Built-in 700 Series Z-Wave Module
  • Includes ZDK 7.1x Z-Wave Library
  • Field-upgradable Firmware
  • Supports multiple Z-Wave frequencies
  • UPC: 757347266834
  • Z-NET Unit
  • AC Power Supply
  • Micro USB Power Cable
  • Quckstart guide
  • 1-year manufacturer's warranty
  • Works with all HomeSeer HS3 and HS4 based systems (including HomeTrollers)
  • Works with Home Assistant running ZWave JS
Customer Reviews
Based on 7 reviews Write a review
