Sonoff ZBDongle-E Zigbee 3.0 USB Dongle Plus – Universal Zigbee Coordinator
Low stock
Zigbee USB Stick
Upgrade your smart home system with the Sonoff ZBDongle-E, a versatile Zigbee 3.0 USB stick designed to act as a universal Zigbee coordinator. Whether you're using Home Assistant (ZHA or Zigbee2MQTT), OpenHAB, or other automation platforms, this dongle provides the flexibility and reliability needed to manage a growing ecosystem of Zigbee-compatible devices.
- Universal Zigbee USB Gateway – Turn your PC, Raspberry Pi, or NAS into a powerful Zigbee hub with the Sonoff ZBDongle-E. Perfect for DIY smart home enthusiasts and integrators.
- Broad Compatibility – Works seamlessly with popular smart home platforms like HomeSeer (Zigbee Plus), Home Assistant (ZHA), Zigbee2MQTT, OpenHAB, Domoticz, and more. Supports over-the-air updates and hundreds of Zigbee devices from brands like Philips Hue, IKEA, Aqara, and Tuya.
- Powered by Silicon Labs EFR32MG21 Chip – Built on a robust and efficient chip that supports Zigbee 3.0, ensuring strong signal range, low power consumption, and reliable performance across your smart home network.
- Secure and Customizable – Flashable firmware allows for full customization to match your ecosystem. Ships pre-flashed and ready for ZHA, with the flexibility to change firmware to Zigbee2MQTT or other applications.
- Plug & Play Setup – Easily connects via USB 2.0. Includes external antenna for improved range and stable connectivity across multiple floors or large areas.
- EFR32MG21 Zigbee Chip
- Zigbee 3.0 wireless
- -10 to +40 C working temperature range
- 75x25.5x13.5mm dimensions
- Zigbee Plus software plugin required for use with HomeSeer systems
- Dongle
- External Antenna
- User Manual
It does not work and Homeseer tech support is non-existent. I followed the instructions. The Zigbee dongle does not work
I was not able to use it. It was not clear that it would not work with my HomeTroller Zee 2 V5
Sorry for the confusion. The OS needs to be more up to date in order for Zigbee2MQTT... which is the engine for the Zigbee Plus plugin.
Substantial improvement over the Z-Wave & Zigbee Stick. With the old stick, my Zigbee network was encountering frequent failures and I thought it was the devices. After setting up and configuring the Sonoff dongle, all the problems evaporated. Adding and configuring the Sonoff dongle was relatively easy and painless.
I plugged it in, my computer acknowledged a USB device had been plugged in, went to the Zigbee plugin to configure, and that's as far as it gets.
So I say, WTF! So, I went to Sonoff website - no help there. Then I read through all the reviews here. And the LAST review was the info I needed: It won't work with Windows 7.
I would be fine with that if Homeseer had included that pertinent info on the product page.
I saw this Zigbee dongle on sale on the Homeseer site and decided to give it a try. I had long ago grown tired of constantly having to tinker with my Conbee/Deconz/Jowihue setup to keep it working. Especially after reboots.
I plugged the Sonoff dongle in, installed the Zigbee Plus plugin, and it just worked. No problems at all so far. And as a bonus, this has a much nicer and more capable user interface. Highly recommended!
