HomeSeer SmartStick ZB Zigbee 3.0 USB Interface/Coordinator/Dongle
In stock
Zigbee 3.0 USB Stick
Unlock the full potential of your smart home setup with the HomeSeer SmartStick ZB, a high-performance Zigbee USB dongle engineered for reliability, range, and seamless integration. Whether you're running HomeSeer, Home Assistant, OpenHAB, or Zigbee2MQTT, this dongle delivers robust connectivity and cutting-edge performance using the latest Silicon Labs technology.
- ✅ Wide Compatibility: Fully compatible with HomeSeer, Home Assistant, OpenHAB, and Zigbee2MQTT. Easily integrate with popular smart home ecosystems.
- 📶 Extended Range Coverage: Features +20 dBm output power and a high-gain +5dBi detachable antenna, ensuring stronger, more stable connections across larger areas and through obstacles like walls and floors.
- ⚙️ Powered by Silicon Labs ERF32MG21 Chipset: Built on the latest-generation Zigbee SoC, offering enhanced signal processing, energy efficiency, and support for a greater number of connected devices.
- 🔧 Plug-and-Play via USB: Compatible with Windows, Linux, and Raspberry Pi systems. Ideal for DIYers and professionals alike.
- 🔐 Secure & Stable Communication: Built-in hardware-level security features ensure encrypted communication between Zigbee devices and your smart hub.
- Optional wall mount available for optimized positioning. Learn more
- Transmission Protocol: Zigbee, IEEE 802.15.4
- Serial Interface Protocol: EmberZNet(EZSP)
- Wireless Range (90 Meters / 300 Feet)
- Operating Temperature: -10 to +50 C
- Weight: 23g
- Works with HS4 based systems running the Zigbee Plus plugin
- Works with Home Assistant running Zigbee ZHA
- Works with Zigbee2MQTT
- SmartStick ZB Dongle
- Long Range Antenna
- 1-year manufacturer's warranty
What is the HomeSeer SmartStick ZB?
The HomeSeer SmartStick ZB is a USB Zigbee 3.0 interface that allows a compatible computer or smart home controller to communicate with Zigbee devices. It functions as a Zigbee coordinator and provides a dedicated Zigbee radio for your smart home system.
What software can I use with the SmartStick ZB?
The SmartStick ZB is designed to work with several popular smart home platforms, including:
- HomeSeer
- Home Assistant
- Zigbee2MQTT
- openHAB
For HomeSeer systems, the SmartStick ZB works with HS4 systems using the Zigbee Plus plugin. Home Assistant systems can use it with ZHA, and Zigbee2MQTT can use it as a Zigbee coordinator.
Can I use the SmartStick ZB and a Z-Wave SmartStick at the same time?
Yes. A computer or HomeSeer system can use separate USB interfaces for Zigbee and Z-Wave. For example, you can use a HomeSeer SmartStick ZB for Zigbee devices and a HomeSeer SmartStick G8 for Z-Wave devices.
How far can the SmartStick ZB communicate?
The SmartStick ZB has a rated wireless range of up to approximately 90 meters (300 feet) under suitable conditions. Actual range will vary depending on building construction, walls, floors, interference, antenna placement, and the Zigbee devices being used.
What antenna does the SmartStick ZB use?
The SmartStick ZB includes a detachable high-gain +5 dBi antenna. The radio provides up to +20 dBm output power, helping provide strong Zigbee communication and improved coverage.
Basically plug-n-play into my existing Z-Net. Simple config with the Zigbee Plus plugin.
I had another brand...is can tell you this has been rock solid connections...temperatures humidities...fireplaces...Definitely worth the investment. Homeseer continues to innovate and my home is second to none as a result. It is incredible the automation I have been able to achieve and improve upon in the last few years!
Works well and, compared to the Sonoff dongle, has better range in real-world conditions.
My Sonoff dongles are now configured as routers and are working well in that role.
Seamless transition from previous Sonoff ZBDongle-E. Increase in zigbee signal levels to all my devices.
I bought this device to connect to my Homeseer system through my z-net as my previous one did which was a Sonof. I haven’t been able to figure out how to make it work. There is no documentation that came with the device and the little documentation I found online does not mention working with a Z-net.
Hi Marty - This does work with a Z-NET (and Pi hub too). If you continue to have issues, please send an email to support@homeseer.com to open a help desk ticket.
