In stock
Upgrade Your Z-NET or HomeTroller Pi G3 to 800 Series
This upgrade kit allows users to upgrade their 500 or 700 series Z-NET, HomeTroller Pi G3 to 800 series Z-Wave technology. The updated controller features improved range, support for Z-Wave long range products and the unit may be configured to work with all Z-Wave frequencies around the world.
📢 800 series Z-Wave Plus v2 chip | User-configurable Z-Wave frequencies for US, EU, UK, AU, HK, MY, IL, IN, RU, CN, JP, KP |
Compatibility
This upgrade kit works with the following products:
- Z-NET (All models)
- HomeTroller Pi G3
- 800 series Z-Wave Radio with user-select able Z-Wave frequencies
- Dual network support (simultaneous control of Z-Wave mesh and Z-Wave long range devices)
- Supports Z-Wave S2 security
- Supports Z-Wave long range technology (up to 1 mile)
- Includes highly optimized antenna for superior range and performance
- Easy upgrade process
Includes International Z-Wave Module
Not in the US? No problem! Z-NET and HomeTroller can now be configured to work around the world. Our Z-Wave module is now compatible with systems in the US, Canada, Europe, Australia, Hong Kong, Malaysia, India, Israel, Russia, China, Japan and Korea. Change the setting from your HomeSeer HS4-powered system.
- Protocol: Sigma serial API
- 800 Series Z-Wave module HAT
- Includes SDK v7.22.2 Z-Wave library
- Field-up-gradable firmware
- Supports multiple Z-Wave frequencies
- 800 series module HAT for Z-NET controllers
- note: HAT circuit board color may be black or green.
- Z-NET (all models) or HomeTroller Pi G3.
- Home Assistant hub with ZWave JS UI add-on installed.
The upgrade kit worked fine. I think the price was ok, not great. I am using my Z-Net with Home Assistant because it's a more modern platform than Homeseer, which I ran for probably 10-12 years...and of those years only had one major software upgrade (HS4) which was in 2020? Anyway, happy enough with the 800 series upgrade, but really enjoying Home Assistant!
Very easy to remove the old hat and install this new one. Just follow the video instructions.
Upgraded a 500 series with EASE! 4 screws, popped off the old hat, installed the new hat, 4 screws back on and powered it up!
Homeseer provides a simple and clear way to backup and restore your devices to the new 800 series and I even did a zwave to zwave plus upgrade at the same time, little more work but totally worth the effort!
Bravo Homeseer folks to offer such an easy upgrade, thanks from a seriously satisfied customer!
I upgraded my old 500 series Z-Net with this new 800 series hat. Very easy install and migration. The new Z-Wave Plus plugin is much easier to use than the old version.
The upgrade is fantastic, once you get it going. It was a long, complicated process for me requiring a reload of the Pi OS, an interim hardware (newer 500 module), and multiple backup and restores. The documentation for this process wasn't clear, is spread across multiple documents, and misses a few details. Support was helpful, although they stopped responding. Fortunately I was able to guess my way though the last couple of steps.
Now that it is done, it really is a huge upgrade. Problem devices are no longer a problem, and the new dashboard gives a great view of all devices in the network.
To do it again, I would probably just buy a new controller instead of upgrading the legacy Pi 2 based Zee S2.
Sorry it took so many steps John but we're glad you got it working and that you consider it a huge upgrade!
