HomeSeer DS100 G8 Door & Window Sensor, 800 Series Long Range Z-Wave Technology
Note: This item has been discontinued and is no longer available. However, our newer Zigbee door/window sensor provides the same features and is also compatible with HomeSeer and many other smart home platforms. For more information, check out the HomeSeer DS150ZB. |
Z-Wave Door / Window Sensor
Our Z-Wave door & window sensor alerts your smart home hub when doors or windows are opened & closed. DS100 G8 works with standard or long range Z-Wave, supports S2 security, is easy to set up, takes regular AAA batteries and comes with all the hardware you need to install quickly. Works with most popular smart hubs.
- Door / window sensor
- Uses conventional AAA batteries for easy battery changes
- Supports Z-Wave Plus and Z-Wave LR (long range) technologies
- Supports S2 Security
- Small and Sleek design
Operation
Install the sensor on a door or window using the supplied hardware. Then pair it to your smart software or hub. A Z-Wave command will be broadcast every time the sensor is triggered. Battery status will also be updated daily.
- Power: (2) AAA batteries
- US Z-Wave Operation
- Z-Wave Plus Certified
- DS100 G8 Sensor Body
- Magnet Piece
- Double stick tape
- Mounting screws
- (2) AAA alkaline batteries
- Manual
Important
- Requires US Z-Wave network
- HomeSeer users: Z-Wave Plus plugin required for parameter settings
- Compatible with HomeSeer, Home Assistant, Hubitat hubs
