1 of 5
HomeSeer DS150ZB Zigbee Door & Window Sensor
SELECT PACK
Regular price $ 17.95 USD
Regular price $ 17.95 USD Sale price $ 17.95 USD
In stock
Zigbee Door / Window Sensor
DS150ZB is a compact, battery-powered Zigbee 3.0 door and window sensor designed to monitor the open/close status of doors, windows, cabinets, and other entry points in your home or office. This sensor offers wide compatibility with popular Zigbee hubs and smart home systems.
Whether you're enhancing your home security or automating daily routines, the DSZB sensor ensures reliable, real-time status reporting with ultra-low power consumption.
Key Features
🔒 Zigbee 3.0 Compatibility
Works seamlessly with Zigbee 3.0 hubs and ecosystems, including HomeSeer, Home Assistant, Hubitat, and more.
🪟 Discreet, Low-Profile Design
Sleek and compact—easy to mount on doors, windows, drawers, or other movable surfaces.
🔋 Long Battery Life
Runs on 2 1632 coin-cell batteries (included) with up to 1+ year of battery life depending on usage and environment.
📲 Instant Alerts & Automations
Get instant notifications when a door or window opens or closes. Trigger scenes, alarms, or other devices in your Zigbee network.
🧲 Reliable Magnetic Contact Sensor
Accurate magnetic detection ensures consistent performance in everyday use.
Compatibility
The DS150ZB sensor is compatible with:
  • HomeSeer HS4 hubs
  • Zigbee2MQTT
  • Home Assistant (ZHA / Zigbee2MQTT)
  • Transmission protocol: Zigbee, IEEE802.15.4
  • Work frequency: 2.405~2.480GHz
  • Wireless distance: Max 90 meters (Empty area)
  • Power: 2*CR1632 Battery
  • Pairing button: Squeeze enclosure to activate
  • LED: For status
  • Waterproof rating: IP20
  • Operating temperature: -10℃~+50℃
  • Operating humidity: Maximum 95%RH
  • Dimension (LxWxH): 44*21*9.3mm (host), 44*8*9.3mm(magnet)
  • Weight: 14g (include battery and magnet)
  • Installation: Mount with double-sided adhesive
  • DS150ZB Sensor Body
  • Magnet Piece
  • Double stick tape
