HomeSeer Z-NET G3 Remote Z-Wave Interface (CLEARANCE)
Condition
Regular price $ 129.97 USD
Regular price $ 149.00 USD Sale price $ 129.97 USD
In stock
Network-Connected Z-Wave Controller
Z-NET is a network-connected 700 series Z-Wave Plus v2 controller that's designed to send & receive Z-Wave commands from HomeSeer (and Home Assistant) smart home software & hubs. Z-NET is the ideal solution for improved performance in large homes or properties with outbuildings (like pool houses or barns)!
📢 ALL NEW G3 Version | 700 series Z-Wave Plus v2 chip | User-configurable Z-Wave frequencies for US, EU, UK, AU, HK, MY, IL, IN, RU, CN, JP, KP
UPDATE
: Z-NET now supports Zigbee with optional Sonoff ZBDongle-E adapter! HomeSeer systems can manage multiple Z-Wave networks and a single Zigbee network.
Clearance Stock
  • Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
  • NEW: Built In 700 series Z-Wave Radio with User-selectable Z-Wave frequencies
  • Ethernet (and WiFi) Connections Allow for Optimal Positioning in Home
  • Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
  • May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Includes Highly Optimized Antenna for Superior Range and Performance
  • Includes Easy to Use Web-Based Management Features
  • Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
  • Case Includes Keyhole slots for wall mounting (with your hardware)
Includes International Z-Wave Module
Not in the US? No problem! Z-NET can now be configured to work around the world. Our Z-Wave module is now compatible with systems in the US, Canada, Europe, Australia, Hong Kong, Malaysia, India, Israel, Russia, China, Japan and Korea. Change the setting from your HomeSeer HS4-powered system.
 In the diagram below, a HomeTroller PRO hub is connected to two Z-NETs, one of which is controlling both Z-Wave and Zigbee products.
  • Z-Wave Plus Certified
  • Protocol: Sigma Serial API
  • Built-in 700 Series Z-Wave Module
  • Includes ZDK 7.1x Z-Wave Library
  • Field-upgradable Firmware
  • Supports multiple Z-Wave frequencies
  • UPC: 757347266834
  • Z-NET Unit
  • AC Power Supply
  • Micro USB Power Cable
  • Quckstart guide
  • 1-year manufacturer's warranty
  • Works with all HomeSeer HS3 and HS4 based systems (including HomeTrollers)
  • Works with Home Assistant running ZWave JS
Condition
OPEN BOX stock includes customer returns that have been opened. These units are in good shape but may have slight cosmetic blemishes. All open box items come with the original manufacturer's warranty and are also covered by our 30-day return policy.
