HomeSeer HSM200 Z-Wave Multi-Sensor - USED
📦 FREE Shipping on orders of $200+
AC Powered Multisensor With RGB Indicator
HSM200 senses motion, temperature and light level and it can be programmed to glow up to 7 different glowing colors when things happen in the home. The unit is line powered so there are no batteries to change and it works as a repeater for your Z-Wave network. OPEN BOX edition.
- Motion, Temperature, and Light sensor
- Includes multi-colored LEDindicator
- Line-powered
- Works as a repeater
- Never needs batteries
- Supports Z-Wave Plus Technology
- Firmware updatable in field by end-consumer
Important Information
Since the HSM200 is line powered, there are no batteries to change and the unit automatically operates as a Z-Wave network repeater. Installation is fast and easy. Just plug into any available 120v outlet and tap the button on the side to join it to your Z-Wave network.
HSM200 is compatible with any HomeSeer HS3-based system, including the full line of HomeTrollers. HomeSeer users can create events to display different colors when motion is sensed, doors are opened, water leaks are detected or just about anything else happens in the home. Color options include red, green, blue, yellow, magenta, cyan and white. The unit can also be programmed to work as a night light after hours.
- PIR Range: 12', 90°
- Temperature Sensor Range: -10-80°C, 0.1°C Resolution
- Light Sensor Range: 0-10,000 LUX
- Power: 120v, 60Hz
- US Z-Wave Operation
- Indicator Colors: Red, Green, Blue, Magenta, Cyan, Yellow, White
- Z-Wave Plus Certified
- Multisensor
- Manual
- Z-Wave certified controller needed for motion, temp, light level sensor
- Color LED feature requires HomeSeer HS3 system or other controller that supports the Z-Wave color command class
Comments
- The sensor reports luminance as LUX by default. If you enable polling, it will then report as %.
Condition
USED stock includes customer returns that have been opened and installed. These units are in good shape but may have cosmetic blemishes and may also be missing hardware. All used items come with the original manufacturer's warranty and are also covered by our 30-day return policy. |
