izHeatmiser Software Plugin for HS3
$ 0.00 USD
$ 0.00 USD
$ 0.00 USD
IMPORTANT: This software plugin is no longer supported. It will remain available for download in the HS3 updater but will not receive any future updates. Check out with this item in your cart to receive a free license.
This software plugin is designed to allow HomeSeer systems to communicate with Heatmiser Wi-Fi Thermostats. The plugin will allow control of the thermostat and regular polling to ensure HomeSeer always displays the latest status from the thermostat.
- Control Heatmiser Wi-Fi thermostats
- Supports control of multiple thermostats
- Read/Set Set Point, Hold Mode, Holiday Return Date, Lock Status, and Run Mode
- Read Current Temperature and Heat State
- Update the Clock
- Poll the thermostat (via a timer and as required via device control)
- Manage thermostat schedules
- HomeSeer HS3 or HSPRO
- One or more Heatmiser PRT-TS WIFI thermostat
