izTexecom Software Plugin for HS3
$ 0.00 USD
$ 0.00 USD
$ 0.00 USD
| IMPORTANT: This software plugin is no longer supported. It will remain available for download in the HS3 updater but will not receive any future updates. Check out with this item in your cart to receive a free license. |
This plugin is designed to interface HomeSeer 3 with Texecom alarm systems interfaces. This lets you read the status of your individual zones, send key presses, and more.
- This plugin allows you to remotely monitor your security system: Zone Status, Area Status, etc.
- In HS3 each Zone, as well as each Area, is represented with a device
- The LCD status display is represented with an HS3 device
- Zones and Areas are updated dynamically
- The LCD status is updated through polling based on a user-controlled timer
- With this plugin, you can send commands to your system by simulating keypad key-presses
- Allows HomeSeer to request information on areas and to refresh the LCD status
- HomeSeer HS3 or HS3 PRO Version 3.0.0.187 or above
- Texecom alarm system with a USB or Serial interface such as the “Texecom JAA-0001 PC-COM Serial Interface Connector” or the “Texecom JAC-0001 PC-USB Serial Interface Connector”
- Texecom USB/Serial interface should be set to “Crestron” mode (your installer should be able to program this)
- The Texecom serial interface should be connected to your HomeSeer PC via a serial connection or connected to your IP network via serial to IP gateway
