HomeSeer Z-NET G3 Remote Z-Wave Interface for HomeTroller and Home Assistant Hubs
In stock
Network-Connected Z-Wave Controller
Z-NET is a network-connected 700 series Z-Wave Plus v2 controller that's designed to send & receive Z-Wave commandsĀ from HomeSeer (and Home Assistant) smart home software & hubs. Z-NET is the ideal solution for improved performance in large homes or properties with outbuildings (like pool houses or barns)!
LIMITED OFFER - Buy this bundle now and you can add HS4 smart home software for FREE! Learn About HS4 |
š¢ ALL NEW G3 Version | 700 series Z-Wave Plus v2 chip | User-configurable Z-Wave frequencies for US, EU, UK, AU, HK, MY, IL, IN, RU, CN, JP, KP |
UPDATE: Z-NET now supports Zigbee with optional Sonoff ZBDongle-E adapter! HomeSeer systems can manage multiple Z-Wave networks and a single Zigbee network.
- Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
- NEW: Built In 700 series Z-Wave Radio with User-selectable Z-Wave frequencies
- Ethernet (and WiFi) Connections Allow for Optimal Positioning in Home
- Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
- May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
- Includes Highly Optimized Antenna for Superior Range and Performance
- Includes Easy to Use Web-Based Management Features
- Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
- Case Includes Keyhole slots for wall mounting (with your hardware)
Includes International Z-Wave Module
Not in the US? No problem! Z-NET can now be configured to work around the world. Our Z-Wave module is now compatible with systems in the US, Canada, Europe, Australia, Hong Kong, Malaysia, India, Israel, Russia, China, Japan and Korea. Change the setting from your HomeSeer HS4-powered system.
Ā In the diagram below, a HomeTroller PRO hub is connected to two Z-NETs, one of which is controlling both Z-Wave and Zigbee products.
- Z-Wave Plus Certified
- Protocol: Sigma Serial API
- Built-in 700 Series Z-Wave Module
- Includes ZDK 7.1x Z-Wave Library
- Field-upgradable Firmware
- Supports multiple Z-Wave frequencies
- UPC: 757347266834
- Z-NET Unit
- AC Power Supply
- Micro USB Power Cable
- Quckstart guide
- 1-year manufacturer's warranty
- Works with all HomeSeer HS3 and HS4 based systems (including HomeTrollers)
- Works with Home Assistant running ZWave JS
![HomeSeer Z-NET G3 Remote Z-Wave Interface for HomeTroller and Home Assistant Hubs](http://shop.homeseer.com/cdn/shop/products/Z-NET-2023-shadow-500_954e6b41-d1c9-4b73-a4af-9a8f58d3519c.jpg?v=1674595689&width=1445)
![HomeSeer Z-NET G3 Remote Z-Wave Interface for HomeTroller and Home Assistant Hubs](http://shop.homeseer.com/cdn/shop/files/Z-NET-G3-HS4-1000.jpg?v=1717186331&width=1445)
