HomeSeer HS-WV100+ Z-Wave Plus Motorized Water Valve
$ 439.95 USD
$ 449.95 USD
$ 439.95 USD
Unit price
per
Low stock
Z-Wave Smart Water Valve
HS-WV100+ is a Z-Wave Plus smart water valve that may be used for a variety of water control needs. Use to mitigate water damage that might be caused by leaks or use to regulate showers and irrigation systems. Great for residential and commercial properties. Works with most smart home hubs.
Features
- Wireless Z-Wave enabled water valve control system
- Use with HomeSeer (and other) home automation systems to remotely and/or automatically control the flow of water
- Use with water sensors to automatically shut water off when leaks are detected
- Use to regulate water usage for outdoor spigots, showers, sinks or irrigation equipment
- Valve includes manual override
Video
- Compatible with US Z-Wave networks (908 MHz)
- Valve circulation medium: Fluid, Air
- Valve body material: Stainless steel
- Valve life expectancy: 70,000 activations
- Valve maximum working pressure: 1.0MPa
- Valve max. torque force: 2 Nm
- Valve operating voltage: DC12V
- Valve working current: = 500MA
- Valve open/close time: = 5 Sec
- Valve environment temperature -15°C~50°C
- Valve liquid temperature range: 2°C~90°C
- Valve protection class: IP67
- Valve safety certification: NSF
- HS-WV100+ water valve controller
- electronically activated water valve
- User Guide
