Blade BLCapture Software Plugin for HS3 (Upgrade)
$ 0.00 USD
$ 0.00 USD
The BLCapture Plugin for HomeSeer allows the user to capture images and videos from a capture device
- Allows user to capture still images from capture device.
- Allows user to capture moving video from capture device.
- Allows user to capture audio in the moving video.
- User can select a video compression to use when capturing moving video. NOTE: Some video compressions do not work with all capture devices so it may cause HomeSeer to lockup.
- User can select an audio compression to use when capturing moving video. NOTE: Some audio compressions do not work with all capture devices so it may cause HomeSeer to lockup.
- Allows plugin actions to be added to HomeSeer events to capture from device.
