Blade BLSecurity Software Plugin for HS4
1 review
$ 0.00 USD
$ 0.00 USD
$ 0.00 USD
BLSecurity
The BLSecurity Plugin for HS4 will allow you to use existing devices and motion sensors to create a home security system.
- Allows configuration of motion sensors and security devices (DS10A)
- User can import all motion sensors from BLRadar (if installed and enabled)
- Security modes are: ARMED, PERIMETER, SLEEP, DISARMED
- User can specify which devices will be active in Perimeter mode
- Users can exclude devices from Armed and Sleep modes
- User can add zones and assign devices
- User can specify how many devices in a zone need to alert before the zone will alert the system
- Multiple users can be assigned to the plug-in, each having a different alarm panel code
- All security activity is logged to the database. Security activity report can be run to show all activity
- User can specify a wave file to be played when an alert is triggered in Armed, Perimeter or Sleep mode
- User can send emails to multiple recipients when an alert is triggered in Armed, Perimeter or Sleep mode
- User can specify various lights to be turned ON when an alert is triggered in Armed, Perimeter or Sleep mode
- User can specify a list of phone numbers that will be called when an alert is triggered in Armed, Perimeter or Sleep mode
- User can assign a security remote to the plug-in and have it control the security modes.
- HomeSeer HS4-Powered System
J
Jim Oneill The Blade BLSecurity software plug-in a simple setup and works great on both Homeseer v4 and previously v3. We have 3 buildings setup with it and it does the job. We run commercial security systems as well and the BL plug in meets or beats the commercial alarm systems (unfortunately insurance companies require a central monitoring service so we have to have dual security infrastructures).
