Dr. McKay DeviceCompare Software Plugin for HS3
DeviceCompare enables HS3 users to compare the values of two separate devices using HomeSeer's powerful event engine. Events can be run if a device's value is set and it is greater than, greater than or equal to, equal to, less than, less than or equal to, or not equal to the value of another device. Events can also be set to only run if a device's value *changes* and it compares to another device.
May also be used as a condition in events that are triggered by some other stimulus.
- Allows events to be triggered if a device's value changes to be less than/equal to, greater than, or not equal to another device
- Can be used as a condition to prevent events from running unless some device compares to another in a particular way
- Ideal for automating climate control by comparing the temperature in a particular room with the thermostat setpoint
