Dr. McKay HS-WD200+ Idle Light Colors Software Plugin for HS3
WD200 Idle Light Colors
When an HS-WD200/WX300+ dimmer is off, the Idle Light Colors plugin changes its normal mode color to some pre-configured color and sets it to a different pre-configured color when the load is on. This provides for a nice look and allows for the user to more easily distinguish if a dimmer is off, or merely at a low value.This plug-in is open source: https://github.com/DoctorMcKay/HSPI_IdleLightColors
- HomeSeer HS3-Powered System
- .NET Framework v4.5 or higher
