DSL KMT Software Plugin for HS3
$ 19.99 USD
$ 0.00 USD
$ 19.99 USD
KMTronic
When Wifi isn't reliable or you need dependable switching we introduce the KMTronic Web Relay, an Ethernet based 8 relay device with optional DIN mounting. With the Web Relay we can control 8 individual relays using HomeSeer and our KMT Plug-in. If you want 1-wire 18B20 temperature sensors then the KMTronic DS18B20 LAN Temperature Monitor has what you need, fully supported by our plug-in.
- Digital Output and DS1820 Temperature Monitoring
- Calculates Temperature in Kelvin, Celsius, Fahrenheit, Rankine, Delisle, Newton, Réaumur, Rømer & Planck
- Ethernet (Wired) for reliability
- TCP/IP Protocol
- Monitored units with error handling
- Queue based processing to avoid loading HS3
- HomeSeer HS3-Powered System
- Compatible with Windows
- KMTronic Devices (either Web Relay or LAN DS18B20 WEB Temperature Monitor or both)
