Home Essentials Bundle #1
Regular price $ 111.88 USD
Regular price $ 139.85 USD Sale price $ 111.88 USD
Holiday Sale Sold out
In stock
 Add Z-Wave to your hub and save big this week! This bundle includes our popular SmartStick G8 Z-Wave interface and two HSM200 Z-Wave multi-sensors. Save 20%.
SmartStick G8 800 Series Z-Wave Controller
SmartStick G8 is the perfect controller for your HomeSeer or Home Assistant smart home hub. It features the latest 800 series LR technology for superior long range performance.
SmartStick G8 Features
  • Z-Wave Plus V2 (800 Series) Interface for use with HomeSeer, Home Assistant and other brand software and hubs
  • Supports Z-Wave Plus V2 (and older) Products
  • Upgrade-able from Series 500 or 700 controllers running ZDK 6.61 or higher (requires HomeSeer Z-Wave Plus plugin or ZWave JS UI 9.9.0 or later).
  • Supports Z-Wave S2 Security + Secure Vault™ - Requires Compatible Software or Hub
  • Supports Z-Wave "Smart Start" Inclusion - Requires Compatible Software or Hub
  • May be Used with Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Supports multiple Z-Wave international regions when used with HomeSeer or Home Assistant software or hubs.
  • SmartStick G8 is field-upgrade-able, allowing users to install the latest firmware updates with any Windows PC.
  • SmartStick G8 Full Description
HSM200 Z-Wave Multi-Sensor
HSM200 senses motion, temperature and light level and it can be programmed to display up to 7 different glowing colors when things happen in the home. The unit is line powered so there are no batteries to change and it works as a repeater for your Z-Wave network.
HSM200 Features
  • Multiple Sensors included to monitor motion, temperature and light levels
  • RGB LED may be programmed to glow different colors when things happen in your home
  • AC-powered - just plug into any 120v outlet and pair with your hub. Never needs batteries!
  • Works as a Z-Wave network repeater
  • Supports Z-Wave Plus technology
  • Firmware may be updated by home owner
  • HSM200 Full Description
  • SmartStick G8 (1)
  • HSM200 multi-sensor (2)
  • User Guides
Compatibility
This bundle includes advanced features that are supported by the following hubs:
