HomeSeer 800 Series Upgrade Kit
In stock
Upgrade Your Z-NET or HomeTroller to 800 Series
This upgrade kit allows users to upgrade their 500 or 700 series Z-NET or HomeTroller to an 800 series Z-Wave technology. The updated controller features improved range, support for Z-Wave long range products and the unit may be configured to work with all Z-Wave frequencies around the world.
📢 800 series Z-Wave Plus v2 chip | User-configurable Z-Wave frequencies for US, EU, UK, AU, HK, MY, IL, IN, RU, CN, JP, KP |
Compatibility
This upgrade kit works with the following products:
- Z-NET (All models)
- HomeTroller Zee S2
- HomeTroller Pi
- HomeTroller Pi G3
- 800 series Z-Wave Radio with user-select able Z-Wave frequencies
- Dual network support (simultaneous control of Z-Wave mesh and Z-Wave long range devices)
- Supports Z-Wave S2 security
- Supports Z-Wave long range technology (up to 1 mile)
- Includes highly optimized antenna for superior range and performance
- Easy upgrade process
Includes International Z-Wave Module
Not in the US? No problem! Z-NET and HomeTroller can now be configured to work around the world. Our Z-Wave module is now compatible with systems in the US, Canada, Europe, Australia, Hong Kong, Malaysia, India, Israel, Russia, China, Japan and Korea. Change the setting from your HomeSeer HS4-powered system.
- Protocol: Sigma serial API
- 800 Series Z-Wave module HAT
- Includes ZDK 7.22.2 Z-Wave library
- Field-upgradable firmware
- Supports multiple Z-Wave frequencies
- 800 series module HAT for Z-NET controllers or HomeTroller hubs
- Z-NET or Z-NET G3 or HomeTroller Zee S3, Pi or Pi G3 flashed with Z-Wave SDK v6.81 or higher.
- Note: older units flashed with SDK v6.51 may also be upgraded but will require an intermediate update to v6.81 with the 500 series upgrade kit.
- HomeSeer HS4 hub with Z-Wave Plus plugin or Home Assistant hub with ZWave JS UI add-on installed.
