1 of 3
HomeSeer FS100-L Z-Wave Dual Sensor & Buzzer (CLEARANCE)
Regular price $ 39.97 USD
Regular price $ 49.95 USD Sale price $ 39.97 USD
4th of July Sale! Sold out
Out of stock
Z-Wave Dual Smart Sensor
Want to turn your regular 'dumb' appliances into smart ones? HS-FS100-L is a Z-Wave light sensor that's designed to report back to your smart home hub when indicator lights turn on, turn off or change color. Use to monitor dehumidifiers, water softeners, washers, dryers and much more!
HS-FS100-L also includes a built-in temperature sensor and buzzer. Use it anywhere you wish to monitor the temperature and/or issue audible alerts for anything that happens in your home.
Clearance Stock
  • No Box items are in like new condition and have been individually tested for full functionality.
Because these are no longer manufactured, they come with no warranty but are covered by our 30-day return policy.
  • Indicator Light Sensor
  • Temperature Sensor
  • Z-Wave controllable buzzer while connected to a power adapter
  • Acts as a Z-Wave repeater when used with optional Micro USB power adapter
Suggested Uses
Think of all the things in your home that have indicator lights. Wouldn't it be great if you could keep track of them even when you're not at home? Now you can! Our new indicator light sensor monitors these lights and reports changes back to your smart home system or hub. Here are just a few things you can do with HS-FS100-L:
Receive notifications when a...
  • Dehumidifier needs to be emptied
  • Humidifier needs to be filled
  • Water softener needs more salt
  • Washing machine turns off
  • Dryer/Washer turns off
  • Computer or network equipment needs attention
  • Home entertainment gear turns on or off
  • Security panel lights come on
  • Heating or cooling equipment need attention
  • The freezer has stopped working, IE: unplugged
  • Air filter needs replacing
Video
  • Sensor Body
  • Indicator light cable with double-stick tape
  • US Z-Wave network
Important
  • Not compatible with SmartThings
