HomeSeer HS-WD100 Z-Wave Plus Scene-Capable Smart Dimmer (CLEARANCE)
$ 49.00 USD
$ 49.00 USD
Unit price
per
Out of stock
Z-Wave Smart In-wall Dimmer Switch
HS-WD100+ works with most smart hubs and is compatible with a wide variety of bulbs. The switch may also be used to trigger scenes and automations by multi-tapping the paddle 2 or 3 times.
Clearance Stock
All clearance items come with the original manufacturer's warranty and are also covered by our 30-day return policy. |
- Handles dimmable bulbs up to 600 watts.
- Support multi-tap and press & hold event triggers up to 3 taps (8 possible triggers)
- Supports instant status when controlled locally
- Compatible with HomeSeer (and many other) smart hubs
- Supports S2 Security
- Works with Alexa and Google Home (hub required)
- Easy 'screw terminal' installation
- Works with HS-WA100+ wall companion for 3-way, 4-way and 5-way circuits
- Includes Z-Wave signal repeater feature
Operation
Configure as a dimmer for bedrooms, family rooms and other areas where dimmed lighting is preferred. Once installed, HS-WD100 works like any other dimmer. However, add it to any HomeSeer system (or other compatible hub) and you'll unleash these advanced features!
Multi-tap Triggers
- Press top or bottom of paddle once - turns attached load on or off and can also trigger 2 HomeSeer events
- Press & hold top or bottom of paddle - dims attached load and can also trigger 2 HomeSeer events
- Press top or bottom of paddle 2 or 3 times - triggers up to 4 more different HomeSeer events
- Compatible with US Z-Wave networks (908 MHz)
- 120 VAC, 60Hz
- Max Load: 600 watt incandescent
- Max Load: 150 watt LED / CFL
- Operating Temps: 0℃ - 40℃
- Supports Z-Wave Plus features
- Supports Z-Wave S2 security
- cUL, FCC, Z-Wave Plus certified
- Forward Phase
- Color: White. Almond color kit available.
- See Condition Description Above
- Z-Wave Core plugin v3.0.9.0 or later
Accessories
