HomeSeer PS100 mmWave Radar Presence Sensor
In stock
Smart Presence Sensor
Upgrade your smart home with the PS100, HomeSeer’s advanced presence sensor designed for accurate, real-time occupancy detection. Powered by mmWave radar technology. The PS100 detects even the slightest motion - like breathing - so your automations stay responsive and reliable.
Whether you're automating lighting, HVAC, or security, PS100 delivers fast, consistent results without the limitations of traditional motion sensors.
IMPORTANT
This is the second release of the PS100 and while quite a bit of internal testing has been done on it, we still consider the unit to be a ‘beta’ product. There may be bugs. Please see the Known Issues section in the PS100 user guide for more information about this. |
What's New
- Redesigned enclosure for a cleaner look and improved performance
- Flexible mounting options (wall, surface, or stand)
- Programmable RGB LED for status, alerts, or custom automations
- Enhanced usability and installation experience
True Presence Detection (mmWave Radar)
Unlike PIR sensors, PS100 detects stationary occupants—perfect for offices, bedrooms, and living spaces where people may sit still for long periods.
Z-Wave 800 Series + Long Range
- Extended wireless range and improved reliability
- Lower power consumption
- Supports Z-Wave Long Range (LR) for larger properties
Highly Customizable
Fine-tune performance with adjustable parameters:
- Detection sensitivity
- Range zones
- Motion vs. presence behavior
- LED notifications and automation triggers
Fast, Reliable Automations
Trigger lights, scenes, and devices instantly based on true presence—not just motion.
Wide Platform Compatibility
Works seamlessly with:
- HomeSeer systems
- Home Assistant
- See compatibility guide for other hubs
- NOT compatible with SmartThings
Ideal Use Cases
- Lighting automation that stays on while you’re still in the room
- Energy savings by turning off HVAC or lights when rooms are empty
- Security awareness with precise occupancy detection
- Bathrooms, offices, bedrooms where traditional motion sensors fail
Installation Options
- Wall mount with included adhesive system
- Use included stand for optimal positioning on shelf or flat surface
Power: USB-C (cable included)
- 24 GHz mmWave sensor
- Dimensions (excluding bracket): TBA
- PS100 sensor in 3D printed enclosure
- 5 volt power supply with right-angled USB-C connector
- Ball-socket adjustable sticky wall mount
- 3D printed stand
- QR code user guide
- HomeSeer or Home Assistant powered hub equipped for use with Z-Wave devices.
So far, this thing has been great. Took a little to get it to pair with my Hubitat, but once I did it worked very well. I use it with XTension on my Mac with a Hubitat. Keeps my lights from going off on my wife when she is in the Living Room reading or watching TV. Definitely will get more of them for my house.
I put one inside a wooden picture frame, behind a home store "painting" on the wall and it works flawlessly. These are the best new home automation devices to come onto the market in years.
The presence sensor is flawless. It is a level up from a standard motion sensor. I use it in my office, and my wife is very happy that the lights don't turn off when she is working at her computer and not moving much. I've purchased four to replace the PIR sensors in some rooms.
