HomeSeer PS100 Z-Wave Presence Sensor (Pre-Production Sample)
Out of stock
NOTE: This pre-production sample has a 3D-printed enclosure and is intended for use in our public beta program. Purchase this unit if you'd like to participate in this program. Availability is limited to one unit per order. 👉 If you intend to wall-mount the unit, we recommend the optional power adapter with the right-angle connector. |
Z-Wave Smart Presence Sensor
The PS100 is a new breed of sensor that uses high-frequency millimeter wave technology to detect very small movements from people, pets, and objects. This makes PS100 the ideal solution for tracking room occupancy and for a wide variety of security needs.
Unlike conventional PIR (passive infrared) motion sensors which can become ‘blind’ to people who are motionless for a time, PS100 is sensitive enough to detect even the slightest movements.
Additionally, PS100 includes wireless Z-Wave technology allowing it to be integrated into many popular hubs.
Note: This pre-production unit has ONLY been tested with HomeSeer software and hubs.
- Ultra-sensitive millimeter wave sensor
- Multi-position mount
- Easy to install
- Easy to adjust
- Powered by USB adapter (optional)
Operation
Install using the supplied hardware and pair with your smart home software or hub. PS100 may be used to trigger events ("automations") when movement is sensed. Use this to turn on lights, send notifications, sound alarms, or change the occupancy status of your home. This sensor will send Z-Wave commands when (a) motion is sensed and (b) when motion has not been sensed for a (user-adjustable) period of time.
- 24 GHz mmWave sensor
- Dimensions (excluding bracket): 2.6" x 1.9" x 0.6"
- USB C power connector
- PS100 sensor
- Adjustable mount
- User guide
- Z-Wave certified smart home hub or software
