Boneyard Sale - Global Caché GC-100-6 Network Adapter (Used – Test Sample)
Out of stock
Global Cache GC-100 Controller
Bring reliable IP-based control to your automation setup with the Global Caché GC-100-6. This versatile network adapter enables seamless control of IR devices over your network, making it a solid choice for integrating legacy AV equipment into modern smart home systems.
Important Note (Please Read):
This unit was previously used as a test sample during development of a HomeSeer integration plugin. As such, it should be considered used and may show minor signs of wear. The unit has not been fully refurbished or reconditioned.
👉 On 4/30/26, this unit was powered on and the web UI was accessed successfully using Global Cache's iHelp discovery tool. No other testing of the unit was done.
What’s Included:
- GC-100-6 network adapter
- Generic 12V 1A power adapter with barrel connector
- (2) IR emitters
Key Features:
- Ethernet-based control of IR devices
- Ideal for home automation and AV integration projects
- Compatible with a wide range of control systems, including custom and DIY setups
Condition:
- Used (test unit)
- Sold as-is
This is a great opportunity to pick up a proven piece of integration hardware at a reduced price—perfect for tinkerers, developers, or anyone building out a custom control solution.
IMPORTANT - PLEASE READ BEFORE PURCHASING What you are buying This device was used to create a HomeSeer plugin. You should consider it a used product. It has been powered on and the web ui has been accessed using Global Cache's iHelp discovery software. It appears to be in good working order. However, it has not been fully tested. Possible issues It may...
Terms of sale This is a final sale item. It is non-returnable and non-refundable, with no guarantees or warranties. The price reflects this. |
