Posixx Cytech Comfort Software Plugin for HS3
IMPORTANT: This software plugin is no longer supported. It will remain available for download in the HS3 updater but will not receive any future updates. Check out with this item in your cart to receive a free license. |
This software plugin is designed to allow HomeSeer systems to connect to Cytech Comfort Alarm systems. By uploading your configurator config file you can add zones and responses as devices in HS3.
- Connect to Comfort using TCP/IP, USB, or Serial Connection
- Uses HS3 device grouping with Parent/Child device relationship
- Support for special DoorBell device (either zone or door phone)
- Compatible with Windows
