Sonoff ZBDongle-E Zigbee 3.0 USB Dongle Plus (OPEN BOX)
No reviews
$ 19.97 USD
$ 39.95 USD
$ 19.97 USD
Unit price
per
Low stock
Zigbee USB Stick
Upgrade your smart home system with the Sonoff ZBDongle-E, a versatile Zigbee 3.0 USB stick designed to act as a universal Zigbee coordinator. Whether you're using HomeSeer (Zigbee Plus), Home Assistant (ZHA or Zigbee2MQTT), OpenHAB, or other automation platforms, this dongle provides the flexibility and reliability needed to manage a growing ecosystem of Zigbee-compatible devices.
- Universal Zigbee USB Gateway – Turn your PC, Raspberry Pi, or NAS into a powerful Zigbee hub with the Sonoff ZBDongle-E. Perfect for DIY smart home enthusiasts and integrators.
- Broad Compatibility – Works seamlessly with popular smart home platforms like HomeSeer (Zigbee Plus), Home Assistant (ZHA), Zigbee2MQTT, OpenHAB, Domoticz, and more. Supports over-the-air updates and hundreds of Zigbee devices from brands like Philips Hue, IKEA, Aqara, and Tuya.
- Powered by Silicon Labs EFR32MG21 Chip – Built on a robust and efficient chip that supports Zigbee 3.0, ensuring strong signal range, low power consumption, and reliable performance across your smart home network.
- Secure and Customizable – Flashable firmware allows for full customization to match your ecosystem. Ships pre-flashed and ready for ZHA, with the flexibility to change firmware to Zigbee2MQTT or other applications.
- Plug & Play Setup – Easily connects via USB 2.0. Includes external antenna for improved range and stable connectivity across multiple floors or large areas.
- EFR32MG21 Zigbee Chip
- Zigbee 3.0 wireless
- -10 to +40 C working temperature range
- 75x25.5x13.5mm dimensions
- Zigbee Plus software plugin required for use with HomeSeer systems
- Dongle
- External Antenna
- User Manual
