Spud Nest Software Plugin for HS3
| IMPORTANT: Google has shut down its "works with nest" API preventing new users from integrating nest with HS3 and other home automation software. This plugin will continue to work for existing users. Going forward, Nest integration will be accomplished via Google Home Assistant. This plugin is no longer available for sale. |
This plugin is designed to interface HomeSeer with Nest devices:
- Nest Learning Thermostat
- Nest Protect: smoke and carbon monoxide detector
- Nest Cameras
This plugin uses the official "Works with Nest" API.
- Allows HomeSeer to read ambient temperature and target temperatures from your Nest Thermostat
- Allows HomeSeer to control your Nest Thermostat temperature and settings
- Allows Homeseer to access smoke, carbon monoxide, and battery info from your Nest Protect
- Allows Homeseer to get and set the Home/Away status
Support
