stefxx FritzTR064 Software Plugin for HS3
This is a FritzBox Plugin that utilize the TR064 interface for secure communications with your FritzBox. It does NOT require telnet access, a feature that is no longer supported by recent firmware versions.
- Call log, configurable number of incoming and outgoing devices, with a configurable device string
- TAM (voice mail), configurable number of devices, with a configurable device string
- Number/Name conversion lookup (via Internet) and other translation options for the DeviceStrings
- Triggers on incoming and outgoing calls with various options to filter on caller ID
- Play voice mails in HS3, both in the TAM device and the incoming calls list through device or event
- WLAN interface devices (2.4GHz, 5GHz and Guest WLAN if supported), and switching on/off though device or event
- Almost all communications through SSL (secure)
- Call log, TAM and WLAN functionality can be individually configured and no devices will be created if the function is disabled
- Enable 'Home Network / Network / Network Settings / Access Settings In the Home Network'
- Enable the Call monitor by dailing #96*5* on a phone connected to your FritzBox
