Steve Jones SDJ-VStat Software Plugin for HS3
SDJ-VStat
A Virtual Thermostat plug-in for HS3. The Virtual Stats (VStats) use any temperature sensors and control devices within HS3 to monitor temperatures and control devices. Each VStat has its own 7-day schedule.
- Any number of VStats can be set up, within the single plug-in, which can theoretically use any temperature sensor devices for input and control any switching devices.
- Each VStat can use multiple input sensors with the current temperature based on the Lowest, Average, or Highest reading of the sensors as required.
- VStats can be heating or cooling stats.
- Each VStat has Day(High), Night(Low), and Away(Frost) SetPoints which can be renamed as desired.
- The target temperature can be temporarily raised or lowered manually as well as toggled between High/Low SetPoints.
- Away(Frost) mode will interrupt the schedules and set the target temperature to the Away(Frost) SetPoint until Auto is reselected.
- Boost mode will force the heating/cooling on for a period of time in 15-minute increments.
- There is a separate (windows only) program for quickly creating and editing 7-day schedules for the VStats although they can also use schedules created and edited in the excellent EasyTrigger plug-in.
- HomeSeer HS3-Powered System
- A special Serial or USB to P1 (RJ11) cable
