Three Palms Home Automation Intesis WMP Software Plugin for HS4
Regular price $ 39.99 USD
Regular price $ 39.99 USD Sale price $ 39.99 USD
IntesisWMP
Discovers, monitors, and controls any air conditioning/HVAC units that support the Intesis WMP protocol Wi-Fi adapters connected to them. Includes charting of temperatures and operational parameters (power, fan speed, setpoint, mode, and more) to monitor your systems and ensure they are working correctly over time. Data is saved daily in JSON data files for download and use separately from the plugin.
This plugin does NOT connect to or interact with the IntesisHome service.
  • Automatic discovery of Intesis WMP-enabled air conditioners on your network
  • Control power, fan, mode, vanes, and temperature setpoint
  • Monitor error status and error code, where available
  • Charting for ambient temperature and setpoint
  • Charting for operational parameters such as power, fan speed, mode, and network connectivity
  • Data download in JSON format files for the last 10 days for separate analysis
  • Controls and status are built based on capabilities discovered by the plugin from the device, eliminating options not supported by your HVAC systems.
  • Supports switching between Fahrenheit/Celsius temperature readings, settings, and charts.
  • Plugin author can recommend/supply compatible Intesis WMP hardware if desired.
  • .NET 4.6.2 or better, equivalent for Mono on Linux/Pi
