Menu
Cart 0
Toby MyZWaveParameters Software Plugin for HS3
  • $ 0
MyZWaveParameters
This tool will give you the possibility to create custom XML files to access Z-Wave device parameters. In a lot of cases these parameters are not displayed in HS3, but through this tool you can create a custom XML file to access them.
Please verify XML file for correct hardware and Firmware version before using. Use at your own risk. Manipulating the Z-Wave parameters may cause unwanted scenarios and not be as expected - for advanced users only.
  • It has several different parameter types to ease the understanding and usage of the device parameters:
  • - integer values (range or preselected values
  • - binary values (switch)
  • - hexadecimal values
  • - combined values
  • Add your own XML files for zwave node parameter configurations
  • HomeSeer HS3-Powered System
  • Requires a running Zwave network and Homeseer Zwave plugin
  • HS3 only version.
