Ultrajones Ultra1Wire3 Software Plugin for HS3
1 review
$ 39.95 USD
$ 39.95 USD
Ultra1Wire3 is the next generation HomeSeer plugin that makes tracking temperature and humidity in your home easy. By using the Embedded Data Systems Intelligent 1-Wire Interface Adapters and/or the Midon Design TEMP08, this plugin automatically creates and maintains a HomeSeer device for each 1-Wire environmental sensor. In addition, the temperature, humidity, barometric pressure and counter values for each 1-Wire sensor are inserted into an underlying database for graphing purposes.
| IMPORTANT: This plugin is considered to be feature-complete by the developer and no future updates are planned. Community support is available via the message board but direct developer support is not guaranteed. Be sure to trial this plugin before purchasing. |
- Automatically discovers and builds HomeSeer devices for each supported 1-Wire environmental sensor.
- Logs all temperature, humidity, counter and barometric pressure readings to an underlying database.
- Temperature, humidity, counter and barometric pressure charts are created using AMCharts http://www.amcharts.com/.
- Ability to trigger HomeSeer3 events based on 1-Wire device sensor readings.
- Error Try/Catch logic to ensure plugin doesn't fail with an unhandled exception.
- Multiple threading allows 1-Wire readings to take place without disrupting the performance of HomeSeer.
- One or more 1-Wire Host Adapters (HA7E, HA7Net, OW-Server, MeshNet Controller, TEMP08).
- One or more 1-Wire environmental sensors.
W
William A. Don't get me wrong, I do like my HS3Pro but this plugin is the simplest, most reliable part of the system!
