UltraJones UltraM1G3 Software Plugin for HS3
UltraM1G3 HSPI is a cool new HomeSeer HS3 plugin for the Elk M1 Alarm Panel. The UltraM1G3 plugin connects to the Elk M1 Alarm Panel using either a serial or Ethernet connection allowing control of the panel using HomeSeer. An extensive list of HomeSeer Triggers and Actions are available to customize your home automation setup.
| IMPORTANT: This plugin is considered to be feature-complete by the developer and no future updates are planned. Community support is available via the message board but direct developer support is not guaranteed. Be sure to trial this plugin before purchasing. |
- Multiple threading allows UltraM1G3 to process events from the Elk M1 without disrupting the performance of HomeSeer.
- Elk M1 command queue executed in its own thread.
- Verification and retry logic to verify critical commands sent to the Elk M1 are processed.
- Error Try/Catch logic to ensure plugin doesn't fail with an unhandled exception.
- Elk M1 real-time clock updated on startup.
- Elk M1 Panel configuration is saved between sessions and loaded on startup.
- Flexibility to allow the creation of only the HomeSeer devices desired (Area, Keypad, Users, Zones, Outputs, Thermostats, Custom Settings, Counters, Tasks, Lighting, System Status and Areas Status).
I have been using the UltraJones Elk M1G plugin for over 5 years. It had been very stable. I first started using it with HS3 and moved to HS4. I have not had any issues with its operation and stability with HS4. It is a great piece of software and lets the ELK zones, tasks, outputs, system status, etc. be used as devices on HS3/4 to trigger events. I use ELK task voice statements for all my announcements to provide a single normal sounding voice for all HS4 and ELK announcements. I highly recommend this package if you want to couple you HS4 with the ELK M1G.
I was using home assistant, and it didn't have anywhere near the capacity that this thing brings. This software works perfect with my elk M1 alarm. Once installed, you can transfer over all your zones partial zones keypads areas status. I use this so when the front doors open it turns on the light and once I close the door it has a delay of 10 seconds. I could've done this with a wireless sensor but using my house hardwire system makes all the sense in the world. You can set it up for your sliding glass doors, windows or whatever. Makes so much sense, no more batteries just use your alarm hardwired system(ELK). If you have an elk M1 alarm system, you'd be a fool not to have this installed.
I've used UltraM1G and MNS Insteon since 2007.
Both products install very easy, have good documentation and run well - I've never had a problem with either product. Very well worth the small license fee.
This is a well written and easy to use plugin. I really wish they made an HS4 version of it. Do not get me wrong it works well on HS4 but it would be nice to have the HS4 mobile features.
Good work
The UltraJones UltraM1G3 Software Plugin works great to control my M1 system. The plugin has been great for triggering events based on zone changes and I am even able to track the temperature status of the keypad in HomeSEER. As expected the developer has continued to update the code and it works in HS4 without any issues.
