UltraJones UltraTiVo3 Software Plugin for HS3
UltraTiVo3 is n HS3 plugin that allows you to use HS3 to control your TiVo DVR from your local area network. The commands allow control of channel changes, user interface navigation and just about anything your existing TiVo remote control can do.
- Automatically discovers the TiVo DVRs connected to your LAN and creates HomeSeer devices to enable network control.
- Monitor & Control multiple thermostats
- Supports System Modes, Fan Modes & Setpoints
- Provides Simulated 'Auto' Mode to switch between Heat/Cool.
- Place or remove Permanent or Temporary Holds
- Monitor Indoor & Outdoor Temperature/Humidity (If provided by your thermostat)
- Thermostat must be controllable by https://mytotalconnectcomfort.com/portal/
- Internet access is required to communicate with the Honeywell servers.
- Windows users must be running Windows Vista or newer.
- Linux (Pi/Zee/SEL) users must run Mono 4.8 or higher.
