Wood Dragon Solutions Fujitsu Mini-Split HVAC Software Plugin for HS3
IMPORTANT: This software plugin is no longer supported. It will remain available for download in the HS3 updater for current license owners but will not receive any future updates. |
This plugin supports monitoring and controlling Fujitsu mini-split air conditioning units equipped with the Fujitsu General Wi-Fi module. The plugin can set the temperature, operating mode (cooling, heat, …), enable economy mode, adjust fan speed and louver position among many other features.
NOTE: This will not work with the older Intesis control modules previously used for Fujitsu AC units. Please see the documentation link for more info about the supported Wi-Fi interface module.
- Set temperature in Celsius or Fahrenheit
- Turn AC unit on/off
- Set operating modes such as cool, heat, fan only, ...
- Set fan speed
- Adjust the position of louvers or set to 'swing mode'
- Mono (on Linux)
- NET 4.0 (on Windows)
