In stock
The Smartest 4-in-1 Z-Wave Sensor for Your Home
Bring motion sensing, ambient light detection, temperature monitoring, and customizable LED notifications together in one compact Z-Wave device. The HomeSeer HSM200 is more than just a sensor — it’s a versatile smart home automation tool designed to make your home safer, smarter, and more responsive.
Perfect for hallways, bathrooms, bedrooms, garages, utility rooms, offices, and more.
Features
- 3 Sensors in One Device
- Customizable RGB Notification Light
- Z-Wave Plus Technology
- Plug-In Convenience
- Advanced Automation Capabilities
Why Customers Love the HSM200
- One Device, Many Uses - The HSM200 replaces multiple standalone sensors while adding powerful notification capabilities.
- Easy Installation - Just plug it in, include it to your Z-Wave network, and start creating automations.
- Reliable Performance - Unlike battery-powered sensors, the HSM200 provides consistent performance without battery changes.
- Flexible Placement - Compact enough for hallways, kitchens, laundry rooms, bedrooms, offices, garages, and utility spaces.
Popular Use Cases
- Smart Hallway Lighting - Automatically illuminate hallways at night with motion-triggered lighting.
- Security Notifications - Flash red when doors are left open or when alarms are triggered.
- Water Leak Alerts - Use bright visual notifications for leak or flood detection events.
- Garage Door Reminder - Display a warning color when the garage door has been left open.
- Temperature Monitoring - Track room temperature for HVAC automations and comfort monitoring.
Specifications
- Technology: Z-Wave Plus
- Power: Standard wall outlet
- Motion Detection: Passive Infrared (PIR)
Sensors:
- Motion
- Temperature
- Luminance
LED Indicator: Multi-color RGB
- Wireless Frequency: US Version: 908.42 MHz
- Hub Required: Yes
- Indoor Use Only
What’s Included
- HomeSeer HSM200 Multi-Sensor
- Quick Start Guide
Compatibility
The HSM200 works with most Z-Wave certified hubs and automation systems, including:
- HomeSeer
- Home Assistant
- Hubitat
Advanced LED notification features may vary by platform.
Frequently Asked Questions
- Does this require a hub? Yes. The HSM200 requires a compatible Z-Wave hub or controller.
- Can I change the LED colors? Yes. The RGB LED can be customized through compatible Z-Wave software and automation systems.
- Does it work with Home Assistant? Yes. The HSM200 works with Home Assistant using a compatible Z-Wave integration.
- Is this battery powered? No. The HSM200 plugs directly into a wall outlet and does not require batteries.
- Can the LED be turned off? Yes. The LED can be configured or disabled through your Z-Wave controller.
Perfect For
- Smart homes
- Home automation enthusiasts
- Security notifications
- Smart lighting systems
- Accessibility reminders
- Vacation homes
- Offices and workspaces
- Hallways and utility areas
Upgrade Your Smart Home with the HomeSeer HSM200
Add intelligent motion sensing, environmental monitoring, and customizable visual notifications to your Z-Wave network with one compact device.
The HomeSeer HSM200 delivers reliable performance, flexible automation options, and unique LED notification features that make your smart home more informative and responsive.
Order yours today and create smarter automations throughout your home.
On HS4. Positives are plug in rather than battery, motion sensor, and temperature. Negative: The LED color can be changed from the device but I cannot get it to change from an event, even one manually run. The directions for updating the firmware do not work as there is no Firmware section.
As expected it works well with the HS4 system and is easy to add/manage. The wording for the timeout for the motion detector going back to no motion is a bit weird and confusing in the z-wave ui for the multi sensor but I figured it out. The default settings for the sensor updates seem a bit long for a device that is plugged in so there’s no concern about battery usage. One thing that would be nice is a way to adjust the motion sensor sensitivity. I see no options for that and the sensors pick up my roomba vacuums moving around. Being able to filter out small devices and pets would be useful.
Got it on sale and decided to give it a try to have an AC powered motion detector. So far, that seems to be working. However, I have experienced a few issues using it with my Z-Box (Fibaro) Hub. These include:
1) The included information sheet had very limited information such as not explaining how to put the device in pairing mode.
2) Smart pairing would not work with the QR code on the device. However, I was able to pair manually and add the security code.
3) The brand new device appeared to be in pairing mode with the LED blinking blue, but you actually have to press and hold a small button on the side for a few seconds. The light blinks blue at a slightly different rate.
4) The temperature sensor is inaccurate. Unable to configure it to Fahrenheit. Can offset the temperature, but it still seems inaccurate.
5) LED control does not report state accurately to my controller. Can set the color in parameters, but the picker and other features don’t seem to work. The LED brightness is feeble.
At the sale price paid and presuming it operates reliably for years, it is fine as a motion sensor and miscellaneous LED light.
Great product. Works as advertised. It was tough finding a motion sensor z wave product that plugs in directly to an outlet.
Was using another brand which missed motion all the time. (Hope that RINGS a bell!) Have been using HSM200 for a few weeks now and it works perfectly. ZWave setup, motion detector to trigger turning on a night light in the bathroom at night. Working with Home Assistant.
