alexbk66 AK MagicHome Software Plugin for HS4
$ 39.00 USD
$ 39.00 USD
$ 39.00 USD
AKMagicHome
Magic Home plugin supports several brands of LED strip controllers, bulbs, and switches that use the same protocol. Chances are high that your bulb or controller (eg. WiFi LED CONTROLLER) will work with this plugin if you can control the device with the Magic Home app or the Surp Life app.
- Provides local control over your LED lights/strips and can auto-scan your network for controllers or for you to manually configure individual lights by their IP address.
- Many brands support LEDENET protocol, i.e.
- Currently implemented RGB(W) control (On/Off, brightness, color)
- Also adding RGBWW (Cool White + Warm White) as well as addressable strips
- HomeSeer HS4-Powered System
- WiFi RGB controllers or bulbs compatible with Magic Home or the Surp Life app.
