alexbk66 AK PumpFuse Software Plugin for HS4
Regular price $ 39.00 USD
AKPumpFuse
Plugin for pumpfuse.com - Sump Pump Alarm & Protector – Monitors Your Pump Energy (HP) and Cuts Off when Dry Run, Overload or Stuck 'On' Float Switch Detected.
PumpFuse is a power monitor and pump protection device that works with all types of well pumps, sump pumps, and utility pumps with no need for water level sensors.
  • PEACE OF MIND – Monitor your pump from anywhere
  • DETECT & PREVENT COSTLY PUMP DAMAGE – The pump protector extends your sump pump life by sensing unusual load on the pump motor and stopping the pump before an expensive breakdown happens
  • SECURE, RELIABLE & FAST – the device works on local network only and because of it is fast and reliable
  • Creates HS Features for Power, Amps, Voltage and Pump Run Time
