Bernold OpenTherm Gateway Software Plugin for HS4
$ 0.00 USD
$ 0.00 USD
$ 0.00 USD
Unit price
per
OTGW Plugin
This plugin allows you to communicate with the OpenTherm Gateway (OTGW), as designed by Schelte Bron. communication occurs in real-time, reading every OT message and does not use summaries. This results in an abundance of information between your OpenTherm thermostat and boiler and allows you to send any command.
- Action for sending a command
- Reads and shows all the known OpenTherm MsgIDs
- HomeSeer HS4-Powered System
- HS4 version 4.2.14.0 or higher
- OpenTherm Gateway (OTGW) connected to LAN
![Bernold OpenTherm Gateway Software Plugin for HS4](http://shop.homeseer.com/cdn/shop/products/523_OTGW_Plugin_Shop.png?v=1674241381&width=1445)
