Blade BLCapture Software Plugin for HS3
Regular price $ 0.00 USD
The BLCapture Plugin for HS3 will allow you to capture images and videos from a capture device.
  • Allows user to capture still images from capture device.
  • Allows user to capture moving video from capture device.
  • Allows user to capture audio in the moving video.
  • User can select a video compression to use when capturing moving video. NOTE: Some video compressions do not work with all capture devices so it may cause HomeSeer to lockup.
  • User can select an audio compression to use when capturing moving video. NOTE: Some audio compressions do not work with all capture devices so it may cause HomeSeer to lockup.
  • Allows plugin actions to be added to HomeSeer events to capture from device.
  • Compatible with Windows
