Blade BLDenon Software Plugin For HS3
6 reviews
$ 0.00 USD
$ 0.00 USD
BLDenon
The BLDenon Plug-in for HS3 will allow you to control Denon A/V Receivers using an ethernet connection.
- Control your Denon A/V receiver using an ethernet connection (only certain models will work with the plug-in).
- HomeSeer HS3-Powered System
R
Ron B. I gave it 4 stars because there are some features that my AVR has that I can't use. One in particular is being able to switch stations when listening to the tuner. I did reach out to Blade, and he said he would look into it.
S
Scott Bessel Love it, allows me to customize lighting based on content or customize volume based on selected source. Works perfect
M
Mark Ryba Works great with Denon AVRX4400H. 0 issues so far.
R
Randolph C. This Plugin works better than most
J
Jeffrey S. It works perfectly with my 2019 purchase AVR6500X Denon in Command Series.
