Blade BLMarantz Software Plugin For HS3
1 review
$ 0.00 USD
$ 0.00 USD
The BLMarantz Plugin for HS3 will allow you to control your Marantz A/V Receivers using an ethernet connection.
- Control your A/V receiver using an ethernet connection (only certain models will work with the plugin).
- Devices all control of the receivers
- Add unlimited receivers
- Use scripting calls to control receivers
T
Taro H. when if you did not work default port number, Pls tory port 23. I did it
