Blade BLML2HS Software Plugin For HS3
Regular price $ 0.00 USD
The BLML2HS Plugin for HS3 will allow you to integrate devices in HS3 into MainLobby/myServer variables. This plugin will also allow control to and from MainLobby/myServer.
NOTE: BLML2HS is the server plugin. The MLServer/myServer plugin (ML2HS) is the client.
  • Allows the integration of HomeSeer devices into MLServer variables.
  • Allows HomeSeer calls to be made from MLServer (this is done via calls in the MLServer plugin)
  • Allows MLServer calls to be made from HomeSeer (this is done via a call in the HomeSeer plugin)
