Blade BLMusic Software Plugin For HS3
Regular price $ 0.00 USD
The BLMusic Plugin for HS3 will allow you to play music stored in folders from HS3.
  • Browse music stored in a directory structure.
  • Create custom playlist from directory-based stored music.
  • Allows user to specify starting volume level for the player.
  • Allows the user to specify the action to take when HomeSeer is speaking
  • Users can setup HomeSeer events and use BLMusic actions to control the player.
  • Users can setup HomeSeer events that trigger on BLMusic triggers (eg: Playback Started, Playback Stopped, etc)
  • Allows user to toggle shuffle play.
  • Allows user to send current media information to all BLBroadcast Plug-In clients (NOTE: BLBroadcast Plugin must be installed)
  • User can setup the maximum number of minutes that the player can be paused before the player is stopped.
  • Dim volume control processing enabled for use with stick-a-switches and palm pads.
  • Cover art can be shown for songs but must be formatted as an image file according to the rules of the plugin
  • Compatible with Windows
