Blade BLPowerMonitor Software Plugin for HS3
Regular price $ 0.00 USD
The BLPowerMonitor Plugin for HomeSeer will monitor your power usage using multiple Brultech monitors, such as the ECM-1220 and ECM-1240.
  • Communicates with the Brultech ECM-1220 and ECM-1240 energy monitors
  • Allows the user to use multiple monitors configured in the Brultech Engine application.
  • Real-time monitoring can be performed in the plugin.
  • HomeSeer devices are created for all monitors so that it is easy to monitor your power usage in MainLobby, etc.
Notes:
  • This plugin is only the client for the Brultech Power monitor. You must also install the Brultech Engine Server Application on a machine on your network.
